11:22 AM
Jul 19, 2012
11:22 AM
Hello everybody,
is there an IBIS model for FX3 slave port pins (CLK, DATA32b, CTL). I am designing and fpga+fx3 board. All my traces have the same length(4.5cm /1.6 inch), same width (0.1mm/4mil) and they run on inner layers. I want to know if i still need the 22 ohm resistors that are in series to those pins on the development board. The VIO of the slave port is connected to 1.8V power supply.
thank you
10:28 AM
Jul 20, 2012
10:28 AM
m_pasovic,
Please create a tech support case to get the FX3's IBIS model.
Otherwise, share your email ID. I will mail it to you.
sai krishna.
12:38 PM
Jul 20, 2012
12:38 PM
12:04 AM
Jul 21, 2012
12:04 AM
Sent to your email.
sai krishna.
05:12 AM
Nov 12, 2012
05:12 AM
Hi All,
IBIS model for FX3 can be found in the following page:
http://www.cypress.com/?rID=68389
sai krishna.
