Hi Guys,
does FX3 have flip/mirror functions?
the signals output to the HDMI is correct, but the FX3 windows(uvc,opened with amcap.exe) is flipped and mirrored.
they both come from the same DSP output. (parallel RGB 888 format)
It happens only when the format is RGB output.
if I cheat it as yuv, the orientation is correct. (same source, just change uvc descriptor to YUV).
