GlJe_1688511
Level 4
Level 4
100 sign-ins 10 likes given 50 questions asked
Hello.
I found the LNK_PHY_TX_TRIM register.
Do you explain the meaning, default value, unit of each items?
     1. PCS_TX_SWING_LOW
     2. PCS_TX_SWING_FULL
     3. PCS_TX_DEEMPH_6DB
     4. PCS_TX_DEEMPH_3P5DB
Thank and Best regards.
Glenn.
YiZ_31
Hi Glenn,
Here are some explanations form wikipedia.
https://en.wikipedia.org/wiki/Amplitude
https://en.wikipedia.org/wiki/Emphasis_(telecommunications)
You can use CyU3PUsbSetTxSwing and CyU3PUsbSetTxDeemphasis to adjust these values if you want.
Eddie
YiZ_31
Hi Glenn,
The information you requested is contained in FX3 TRM. Location: Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\doc\firmware\FX3_TRM.pdf
Eddie
Hello Eddie.
Do you have the waveform image explained it?
I am sorry,
I don't know the meaning not at all.
Thanks and Best regards.
Glenn.
YiZ_31
Hi Glenn,
Eddie
Hello Eddie.
Glenn.
