I am working on a custom board with a CX3 chip to interface an OV5647 sensor with a computer. The GPIO pins that are meant for the UART interface have all been left unconnected and as a result I cant use the UART interface for debugging purposes. Is there any way to do the same action via the USB interface directly?
Please look at the given KBA for details on debugging through USB: https://community.infineon.com/t5/Knowledge-Base-Articles/Using-CyU3PDebugPrint-API-to-Send-Debug-Me...
AliAsgar
AliAsgar
You can additionally look into the following thread too for adding CDC interface and getting Debug logs in CX3 using CDC interface:
https://community.infineon.com/t5/USB-superspeed-peripherals/Add-CDC-device-to-CX3/td-p/275828
Jayakrishna
