LuTa_4642501
Welcome!
The example cyfxusbdebug only outputs garbage over the interrupt endpoint.
Output:
root@raspberrypi ~ gcc int.c -o int -lusb-1.0 ; ./int
�xV4�xV4"�xV42�xV4B�xV4R�xV4b�xV4r�xV4��xV4��xV4��xV4��xV4��xV4��xV4��xV4��xV4�
xV4xV4"xV42xV4BxV4RxV4bxV4rxV4�xV4�xV4�xV4�xV4�xV4�xV4�xV4�xV4�
!xV4!xV4"!xV42!xV4B!xV4R!xV4b!xV4r!xV4�!xV4�!xV4�!xV4�!xV4�!xV4�!xV4�!xV4�!xV4�
1xV41xV4"1xV421xV4B1xV4R1xV4b1xV4r1xV4�1xV4�1xV4�1xV4�1xV4�1xV4�1xV4�1xV4�1xV4�
AxV4AxV4"AxV42AxV4BAxV4RAxV4bAxV4rAxV4�AxV4�AxV4�AxV4�AxV4�AxV4�AxV4�AxV4�AxV4�
C software used to test:
#include <stdio.h>
#include <libusb-1.0/libusb.h>
#include <stdint.h>
#include <string.h>
int main(int argc, char*argv[])
    int res                      = 0;
    libusb_device_handle* handle = 0;
    int kernelDriverDetached     = 0;
    int numBytes                 = 0;
    int a,b;
    unsigned char str[128];
    res = libusb_init(0);
    if (res != 0) {
        fprintf(stderr, "Error initialising libusb.\n");
        return 1;
    handle = libusb_open_device_with_vid_pid(0, 0x04b4, 0x00f0);
    if (!handle) {
        fprintf(stderr, "Unable to open device.\n");
        return 1;
    if (libusb_kernel_driver_active(handle, 0)) {
        res = libusb_detach_kernel_driver(handle, 0);
        if (res == 0) {
          kernelDriverDetached = 1;
        } else {
          fprintf(stderr, "Error detaching kernel driver.\n");
          return 1;
    res = libusb_claim_interface(handle, 0);
    if (res != 0) {
        fprintf(stderr, "Error claiming interface.\n");
        return 1;
    for (a=0;a<100;a++) {
        memset(str, 0, 128);
        res = libusb_interrupt_transfer(handle, 0x81, str, 128, &numBytes, 1000);
        if (0 == res)
            printf("%s\n", str);
        else
           fprintf(stderr, "Error receiving message %d.\n", a);
    res = libusb_release_interface(handle, 0);
    if (0 != res)
      fprintf(stderr, "Error releasing interface.\n");
    if (kernelDriverDetached)
        libusb_attach_kernel_driver(handle, 0);
    libusb_exit(0);
    return 0;
Please follow up in this thread: Bug in cyfxusbdebug, doesnt work on USB 3
Yatheesh
LuTa_4642501
Welcome!
With a patch from Bug in cyfxusbdebug, doesnt work on USB 3
The new garbage is:
8 #xV4#
8 #xV4"#
8 #xV42#
8 #xV4B#
8 #xV4R#
8 #xV4b#
8 #xV4r#
8 #xV4�#
8 #xV4�#
8 #xV4�#
8 #xV4�#
8 #xV4�#
8 #xV4�#
8 #xV4�#
8 #xV4�#
8 #xV4#
8 #!xV4#
8 #!xV4"#
8 #!xV42#
8 #!xV4B#
8 #!xV4R#
8 #!xV4b#
8 #!xV4r#
8 #!xV4�#
8 #!xV4�#
8 #!xV4�#
8 #!xV4�#
8 #!xV4�#
8 #!xV4�#
8 #!xV4�#
# Userspace code used for test:
#include <stdio.h>
#include <stdint.h>
#include <string.h>
    int res                      = 0;
    int numBytes                 = 0;
    int a,b;
    if (res != 0) {
        return 1;
    if (!handle) {
        return 1;
        if (res == 0) {
        } else {
          return 1;
    if (res != 0) {
        return 1;
        if (0 == res)
            printf("%d #%s#\n", numBytes, str);
        else
    if (0 != res)
    libusb_exit(0);
    return 0;
Yatheesh
