Greetings,
I was wondering anybody encountered this failure: "Error, "Write failed. Aborting" while programming the firmware to the particular eMMC device, which is Koxia THGBMJG6C1LBAIL (8GB, eMMV 5.1 compliant). We use SanDisk iNAND7250 and this device has no issues to program the firmware using 'cyfwstorprog.exe.'
[Problem description]
Two partitions, and a user partition were successfully created but while programming the firmware, I got the following error:
USB Superspeed Peripherals
Please note that CYUSB3025 is compliant to eMMC 4.41 and the cards used are eMMC 5.1.
Please confirm if the THGBMJG6C1LBAIL is backwards compatible
If yes, please share the UART debug prints (GPIO[53] - GPIO[56]) when the issue is seen
Rashi
[Additional info.]
I successfully programmed the firmware twice using a brand-new board. Then firmware is not able to program to the eMMC flash at all.
Rashi
Hello Rashi,
Thanks much for your tips.
Perhaps these may be root causes:
* PCB assembly issue.
* Power up sequence of eMMC.
* As you mentioned, a compatibility issue.
Unfortunately, UART pins are not reachable...
I will keep you posted on this.
Many thanks,
-kcn
Please let me know if the issue is resolved
Rashi
