Starting layout of a design based on the Cy4609-RDK-BOARD and downloaded the zip file "630_60155-01_CY4609_final_20140407"
It does not have any PCB layout info in it. Does anyone know where I can get gerbers or Altium PCBdoc or allegro pcb files? It would save me a lot of work.
thanks
Tony
Hi Tony,
The Gerber files will be included in the hardware folder on complete kit installation but the folder you downloaded is only for the schematic files and PCB library as mentioned. I have attached the complete hardware folder, please extract the Gerber files from the *.zip folder inside.
Sananya
Hello Tony,
Please find the hardware files of CY4609 RDK at- https://www.cypress.com/documentation/development-kitsboards/cy4609-hx3-usb-30-hub-reference-design-...
I hope the Gerber and layout files in the folder are what you're looking for.
Sananya
Exactly, that's what I thought and I went there and downloaded the ." CY4609 HX3 RDK schematic and PCB library (Altium tool format).zip",
It has schematic folder, schematic library, PCB Library, and PDF schematic but doesn't have any gerbers or PCB.Doc file. Is it magically hidden in any other files listed on the page?
Tony
Hi Tony,
Sananya
