Want to try the example given by the SuperSpeed Explorer Kit User's Guide. But cannot locate the streamer.exe in directory
EZ-USB FX3/1.3/application/cpp/streamer/x86/Release
as recommended by the document.
There is an app in that directory called 'streamer', but it does not run properly on Window10. The streamer solution under ../x86/ was built with VS2008 and VS2015. They don't run in my VS2019, hence cannot rebuild the executive it. Where can I get an updated streamer.exe. Or anyone has experience in building a new streamer.exe using VS2019 ? Advice would be very appreciated.
Please find the streamer folder attached which has the streamer.exe in the given path location.
What errors are being seen when building the current streamer solution in your Visual Studio Code Application?
AliAsgar
