hello every one
                             we are working on  fx3s provided by Cypress ,i am  trying to debug with segger on slavefifo sync example segger debug configuration is done as per the steps included in the EZ-USB Suite User Guide. after debugging i am unable to check with  break points to transmit and receive functions , but those functions are not executing in my case , i checked by adding break points . can any one suggest me what i have to do ? to verify transmit and receive functions are working fine . if i had misplaced  break points suggest me where exactly i should add
the break points.
abhinavg_21
Please mention whether you are able to halt the CPU or not. If not please attach the screen shot of the error you are getting.
Thanks & Regards
Abhinav
