Console 窗口输出什么信息?
13:25:35 **** Incremental Build of configuration Release for project USBVideoClass ****
cs-make all
'Building target: cyfxuvc.elf'
'Invoking: ARM Sourcery Windows GCC C Linker'
arm-none-eabi-gcc ./camera_ptzcontrol.o ./cyfx_gcc_startup.o ./cyfxtx.o ./cyfxuvcdscr.o ./sensor.o ./uvc.o -T"C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\/firmware/common/fx3.ld" -nostartfiles -Wl,-Map,cyfxuvc.map -Wl,-d -Wl,--no-wchar-size-warning -Wl,--gc-sections -Wl,--entry,CyU3PFirmwareEntry "C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\\firmware\u3p_firmware\lib\fx3_release\cyfxapi.a" "C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\\firmware\u3p_firmware\lib\fx3_release\cyu3threadx.a" "C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\\firmware\u3p_firmware\lib\fx3_release\cyu3lpp.a" "C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\ARM GCC\\arm-none-eabi\lib\libc.a" "C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\ARM GCC\\lib\gcc\arm-none-eabi\4.5.2\libgcc.a" -mcpu=arm926ej-s -mthumb-interwork -g -gdwarf-2 -o"cyfxuvc.elf"
arm-none-eabi-gcc: error: C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\ARM GCC\\lib\gcc\arm-none-eabi\4.5.2\libgcc.a: No such file or directory
cs-make: *** [cyfxuvc.elf] Error 1
13:25:36 Build Finished (took 212ms)
把 ARMGCC_VERSION 改为 4.8.1
請問怎麼改呢?
