USB superspeed peripherals
where can i get the driver of  FX3  for windows10.
Please create a tech support case for the same. They will provide you.
Already Windows update was activated. We will upload the driver with the next SDK release.
JuIn_1625121
100 sign-ins First solution authored 100 replies posted
I need the driver for FX3 for Windows 10 IOT 64bit.
The driver is not included in the latest SDK 1.3.3 released at Jun 24, 2016.
Do I need to create a case?
The drivers can be found here.
Drivers for EZ-USB® FX1™, FX2LP™ , and FX3 - KBA94413
-Madhu Sudhan
Dear Mady,
when I use the driver you just provided (WIN10/x64), the device (Cypress FX3 USB BootLoader Device) does not work and I have the following error message in the device manager :
" The driver for this device has been blocked from starting because it is known to have problems with Windows. Contact the hardware vendor for a new driver. (Code 48) "
I also tried WIN10/x86 with the same result...
Well I tried a lot of versions, Driver version 1.2.3.10 from 21/08/2014 is the only one my Win10 lets work.
I'm also face to some issue when trying to install win10 driver : I've used the KBA94413 link and updated the .inf file for the different OS versions and on win10/x64 (Pro 1703) I get the following error :
Windows encountered a problem installing the drivers for your device.
Windows found drivers for your device but encountered an error while attempting to install them :
Cypress FX3 USB Bootloader Device
The hash for the file is not present in the catalog file. The file is likely corrupt or the victim of attempting.
JuIn_1625121
Installing both FX 3 driver and USB-UART driver on Windows 10/64 bit PC will result in an error and installation will not be successful.
[phenomenon]
1) Install USB-UART driver first.
2) When trying to install the FX3 driver next time, the following message appears.
3) FX3 driver can not  be installed  manually from Device Manager.
Could you tell your opinion?
