GiSa_4520796
Level 4
Level 4
First like received
Can I use file systems called streamwriter and streamreader in FX3S device to write a text file into SD Card.
Srujana.
YashwantK_46
100 solutions authored 50 solutions authored 50 likes received
Hi Srujana,
There's no support for using StreamReader or StreamWriter in FX3S or any examples as such.
You would need to get an in-depth understanding of both the System.IO classes and the MSC system calls inorder to implement a host application on your own which can help you with your application.
Regards,Yashwant
YashwantK_46
Hi Srujana,
Regards,Yashwant
