Can I use file systems called streamwriter and streamreader in FX3S device to write a text file into SD Card.
Srujana.
Hi Srujana,
There's no support for using StreamReader or StreamWriter in FX3S or any examples as such.
You would need to get an in-depth understanding of both the System.IO classes and the MSC system calls inorder to implement a host application on your own which can help you with your application.
Regards,Yashwant
Hi Srujana,
Regards,Yashwant
