- Email to a Friend
Hi, I am try to Write Firmware into the SPI Flash "S25FL127SABMFI101". Write is Successful but unable to boot the Firmware .
I able to erase and read SPI flash.
So, Guide me what is the issue??
Flashing from Control center is successfully boot the Firmware.
I am using the "USBspiDMA " example code.
And attach me Application Code.
- Email to a Friend
Based on my understanding, you are able to download the firmware into SPI flash and boot properly when control center application is used. But, when you use your own application, you are able to write the firmware to the flash but not able to boot it properly. Please correct me if my understanding is wrong.
If my understanding is correct, then please try the following:
1. Write the firmware using the application into the flash
2. Read back the complete firmware from the flash by adding required code in the application
3. Compare the image file with the data received from the flash
Please check if the data in the image file and the data read from the flash are same or not. If not, then please check where the mismatch occurs. This can be used to debug the problem.
Jayakrishna
- Email to a Friend
Jayakrishna
