yaqi_4776616
Level 4
Level 4
50 sign-ins 25 replies posted 25 sign-ins
Hi
  After I have created the CX3 project, configured all the parameters and saved them, why didn't the system automatically generate the cyu3imagesensor. c file.Where should I configure the image sensor, or where can I find cyu3imagesensor. c file?
JayakrishnaT_76
Please let me know which version of FX3 SDK is used for creating the project. If it is not 1.3.4 (latest version of FX3 SDK), then please download it from the following link:
https://www.cypress.com/documentation/software-and-drivers/ez-usb-fx3-software-development-kit
I tested this at my end and found that cyu3imagesensor.c  and cyu3imagesensor.h are generated once the cycx3_uvc.c file was saved. Please refer to the following KBA if you have any doubts while using the MIPI configuration utility.
Steps to Setup up MIPI CSI Camera Solution with CX3 – KBA225748
Jayakrishna
Jayakrishna
JayakrishnaT_76
Jayakrishna
Jayakrishna
