On my CX3 board, the USBBulkSourceSink firmware example enumerates correctly, whether my board is is connected to a USB 3.0 or 3.2 socket.
However, when I download my own firmware onto the board, then it enumerates correctly when connected to the 30 socket, but not the 3.2 socket.
Is there something specific the firmware needs to do to allow it to enumerate correctly when connected to a USB 3.2 socket?
USB Superspeed Peripherals
Please let us know the changes the between the default UsbBulkSrcSink firmware example and the custom UsbBulkSrcSink firmware
With the default firmware and USB 3.2 socket, does the device come up in device manager with yellow mark or does it not enumerate at all? If it doesn't enumerate at all, please check if none of APIs in the firmware are failing before CyU3PConnectState is called.
Rashi
Rashi
