Which Device can interface a USB3.0 Camera.
MaXi_1246331
Level 4
Level 4
50 replies posted 25 replies posted 10 replies posted
I have a  camera that transfer data using USB3.0 interface.
Which series of device can be used for the purpose?
If the device is not only used to receive data from the camera, but also process the frame, and response it by controlling the motor, which device satisfy this usage?
Unfortunately, we do not have any device that can support your application requirement.
AliAsgar
AliAsgar
1000 replies posted 250 solutions authored 750 replies posted
We essentially provide two variants of USB superspeed peripheral controllers for interfacing a USB 3 camera with different camera interfaces.
For a camera with MIPI CSI interface, we provide EZ-USB CX3, which is a programmable MIPI CSI to USB 3 camera controller. More details on this product can be found here :https://www.infineon.com/cms/en/product/universal-serial-bus-usb-power-delivery-controller/periphera....
For cameras with interfaces other than MIPI CSI,  we provide EZ-USB FX3, a superspeed peripheral controller. More details on this product can be found here :https://www.infineon.com/cms/en/product/universal-serial-bus-usb-power-delivery-controller/periphera....
More details on your application with FX3 can be found in this application note :https://www.infineon.com/dgdl/Infineon-AN75779_How_to_Implement_an_Image_Sensor_Interface_with_EZ-US....
Both these products will satisfy your requirements.
AliAsgar
I do not think CX3 satisfy the requirement, because the camera's interface is USB3.0, not MIPI. Do you agree my conclusion?
As to FX3, If FX3 connect the camera, Does FX3 should be used as the host? it get the image from the camera and process the data inside FX3. Does FX3 satisfy this application?
I hope FX3 be the host, I do not have PC or any other processor in my system.
Can you share with me the datasheet of the USB 3 camera?
I can give more comments once I have the datasheet.
Also do let us know what type of processing of frames is needed on the device side?
AliAsgar
I need to find and locate a bright blob at a dark background. The frame rate is around 500fps. If the calculation burden is too heavy, I can consider transfer date to FPGA for processing.
AliAsgar
