Hi all,
I decided the example I'd like to follow through is the back to back master/slave as outlined in AN87216 .
The AN states on page 1 "Firmware source code and GPIF II state machines for both master and slave FX3 kits are attached to this application note." The AN also lists table 4 (below). I have the latest SDK (1.3.4) and GPIF II designer, but I don't see these filenames anywhere. Also, what does it mean "the files in the attachment to this Application Note"?
The Infineon page for USB Super-Speed Code Examples lists the AN87216 , as shown below. All the references are circular and the location of the code remains a mystery to me.
scroll down to AN87216 .....
Click on this and the application note opens as PDF. Where is the associated folder mentioned in same PDF? What am I missing?
cheers,
Paul
Hi Paul,
Please find the source files attached along with this response. We will check internally and fix the issue with the website as soon as possible.
Jayakrishna
