ScBr_784201
First solution authored First like given
We're trying to figure out the proper way to connect a USB Type C connector to an EZ-USB FX3S SuperSpeed USB Controller (CYUSB303X).  The dev kit schematic has a Type B connector, which is simpler than a Type C.  The latter has pins for four differential pairs, and it has CC pins, among other things.  The FX3S has only two differential pairs.  I believe that we would just connect the FX3S Rx and Tx pair to the corresponding pair on one side of the connector, i.e. pins A2/A3 and B10/B11.  What I don't know about is how to handle the CC pin next to the pair.  The FX3S doesn't appear to support the Configuration Channel, but my understanding that negotiating the transfer mode via CC is important.  How is this handled?
Scott
Rashi_Vatsa
Hello Scott,
Please refer to this KBA Designing FX3™/CX3-Based USB Type-C Products - KBA218460 for handling the CC line while designing FX3S based products with a Type C connector.
Note: There is a modification in the above KBA that will be updated soon. If you are using a Type C receptacle in your design, the AC coupling capacitors on the SuperSpeed TX lines should be placed between the MUX and the Type C receptacle.
Please let me know if more queries on this.
Rashi
Rashi
Rashi_Vatsa
Hello Scott,
Rashi
Rashi
Perfect, thank you!
Scott
