I'm using denebola kit,and I need to know what are the various ways to update firmware through DFU?
USB Superspeed Peripherals
You can use https://community.infineon.com/t5/Resource-Library/FX3-Fail-Safe-Firmware-Update/ta-p/246074 as reference
- Initially, the SSBL (second stage bootloader) and the primary firmware can be programmed to EEPROM/FLASH.
- On power up, the based on the PMODE lines status , let CX3 boot with SSBL. The SSBL can check if the firmware at a particular location ( for example 0x6000) is valid. If yes, CX3 will boot with the primary firmware.
- When firmware update command is sent by the host, the primary firmware can switch back to SBBL and receive the firmware and write to EEPROM/FLASH
- Once the updated firmware is written successfully (without any errors), SSBL can boot the device with update firmware if the firmware is valid
Please note that the host application to send the updated firmware needs to be developed.
If you want to use the host app and image combine utility from this, you can do that as well. As you wan to update a firmware initially you can keep both primary and secondary firmware as same firmware (in addition to SSBL) and update the secondary firmware later (during the update)
Rashi
Please let me know if you want to implement the USB DFU Class to your device for the firmware update as provided by USB org https://www.usb.org/sites/default/files/DFU_1.1.pdf or do you have any other requirement.
If you do not want to use USB DFU class, please refer to this blog https://community.infineon.com/t5/Resource-Library/FX3-Fail-Safe-Firmware-Update/ta-p/246074
If yes, please refer to this spec/blog and let me know if there are queries.
Rashi
I'm trying to use following for denebola kit.
https://infineon.github.io/dfu/dfu_sdk_api_reference_manual/html/index.html
Thank you.
The DFU Middleware library that you are referring to is relevant to the devices supported by ModusToolBox (for example PSOC6)
You can refer to this blog FX3 Fail Safe Firmware Update - Infineon Developer Community for firmware update on CX3
Rashi
but the link you said to refer, says 2 images should be combined and uploaded, but I need to update to new firmware in feature, is there any ways to use DFU instead of DFU protocol defined by usb.org
Thank you.
Rashi
