If I want to only use high speed USB 2.0 with the FX3, can I just add the descriptors for USB 2.0 and leave the USB 3.0 ones out? Will that then enable the device to only work at USB 2.0? I only intend to use the device in a USB 2.0 port, but if I did put it into a USB 3.0 port I would want it to run at USB 2.0.
You have to disable SS in CyU3PConnectState call.
br,
kalev
Please change the parameters of the following function in your ApplnInit function:
apiRetStatus = CyU3PConnectState(CyTrue, CyFalse);
sai krishna.
I call the apiRetStatus = CyU3PConnectState(CyTrue, CyFalse); and I do connect in Hi Speed mode. I also deleted the superspeed descriptors and their registration with CyU3PSetDesc(...). Under windows 7, I get the notification that "This device can perform faster if you connect it to a USB 3.0 port." How do you enumerate such that the driver considers you USB 2.0 only as your maximum capability?
Please refer the below knowledge base article.
Prevent “This device can perform faster” Pop-up – KBA220436
It shall help you.
Thanks & Regards,
Shanthakumar
