Well In my project I am interfacing USB FX3 board with MAX2769 , which has 3 SPI lines. So, I am changing Sw as using MISO pin to use bi-directional or interfaceing MISO and MOSI pins with 10k register to signal DATA line on chip. Can you advise me.
Prashant
 Hi Prashnt,
This Madhu who is also handling the Tech Support case you created.
i will update on this within tomorrow.
regards,
- Madhu Sudhan
