I am currently trying to modify both FPGA and FX3 example projects for streamIN and streamOUT to test our 8bit GPIF interface and 8bit FX3.
My question is, once I have done that, is the "Streamer" Software able to calculate a datarate even in 8bit mode ?
Many thanks!
Adrien
SrinathS_16
250 solutions authored 100 solutions authored 100 likes received
Hello Adrien,
The data bus width on the GPIF interface does not matter for using the Streamer software. It is a host application which is used to read data from the USB interface in chunks of 1024/512 bytes depending on the type of endpoint and the USB spec version.
Srinath S
SrinathS_16
Hello Adrien,
Srinath S
