kvinod423
Trying to install the ezusb eclipse suite that comes with the SDK download. But the ezusb suite is a older version and doesn't work with latest version of java. Need latest ezusb suite which works with latest version of Java.
Biren_R
First question asked First like given 250 sign-ins
EZUSB Suite work with java 1.8.0 I suggest using this command to install java8, Let me know if you still face an error after this.
sudo apt-get install openjdk-8-jdk
Biren
Biren_R
Can you please provide the below details it will help us provide a better solution?
- Which Linux distribution are you using?
- Which java version are you using?
- what error are you getting when start EZ suite?
Biren
kvinod423
Linux version: 5.17.11-1rodete2-amd64
Java version: openjdk 11.0.13
Java version incompatible with the eclipse version (Eclipse version is old, JDK/Java version required by the eclipse is also older and deprecated), So couldn't install the EzUSB eclipse version.
Attached the error screenshot...
Biren_R
Biren
kvinod423
I am receiving the same error even after installing Java 1.8.0
Seems like eclipse version that is getting downloaded with linux package is outdated!!
Biren_R
Can you please provide the log also I can see from the last log EZUSB Suite using 11.0.15 and that's why it was not working, check to log it using java 1.8.0?
Biren
kvinod423
I was able to launch the EzUsb Suite after switching the java version to 1.8
Thanks for the help..
