I'm using denebola kit for for development of DFU and I'm using this https://infineon.github.io/dfu/dfu_sdk_api_reference_manual/html/index.html , But I'm unable to find any name of Denebola kit while trying to creating project.
USB Superspeed Peripherals
Please refer to the following thread:
As mentioned in the above thread, the link that is described in your thread refers to the DFU middleware library that is relevant only for devices supported by ModusToolBox. Also, this particular DFU protocol is not the same as the DFU protocol defined by usb.org
Currently, CX3 is not supported by ModusToolBox. So, you cannot create a project using ModusToolBox for CX3.
For creating a project for CX3, you can make use of the EZ USB Suite that comes along with FX3 SDK. The link to download FX3 SDK is given below:
Jayakrishna
Jayakrishna
