Hi team,
I added different resolutions to my custom camera board with the help of this link .
I have taken care of probe control settings and descriptor settings while adding different resolutions.
Currently I am facing some issues and I would like to have a help from you.
1. I can able to stream 13MP resolution over USB 2.0 but for some lower resolutions like VGA I'm getting black screen in AMCap. But I am getting image in windows camera app, why is this happen ? Did I miss anything?
2. 13MP resolution streaming is perfectly being done and I have added still capture capability to it. When I try to capture image, the streaming is getting interrupted and on to UART log side I'm getting DMA_RESET(continuously starting and stopping the App). May I know why this happening?
Your help is most appreciated.
Thank you,
Abdul.
Hi Abdul,
I originally thought that if the GET/SET requests from the host are not handled properly this issue is seen.
Please refer to this thread : https://community.infineon.com/t5/USB-superspeed-peripherals/host-application-compatability/m-p/3613....
But after going through the UART prints, there are commit buffer failures occurring. Maybe the host is slow in reading the data from the host. Please refer to this thread for details on this issue: https://community.infineon.com/t5/Knowledge-Base-Articles/FX3-Error-in-CyU3PDmaMultiChannelCommitBuf....
Please share with us wireshark traces when the issue is seen.
Also is the issue seen with lower resolution and lower frames per second?
AliAsgar
Hi Abdul,
1. Could you please share your firmware with us, if possible?
If some UVC requests are not handled properly, stream works in Windows camera app but doesn't work with Amcap.
2. What method of still image capture is used?
AliAsgar
Hi AliAsgar,
"Could you please share your firmware with us, if possible?"
Sorry I cant able to share the firmware with you but I can give some observation results to you.
i. Using camera app I am getting stream and I can able to see the correct frame information in UART logs.
ii. Using Amcap when i try to set new capture format I can see a blank see and UART logs are like DMA_RESET Appstart and AppStop continuously.
I am handling those UVC requests in a function called SetImageSensorStillResolution() where I configure the MIPI-CSI interface parameters over I2C using CyU3PMipicsiSetIntfParams() API and stimulating ISP.
Please let me know what I missed here.
"What method of still image capture is used?"
To get the still image capture, I am following the method2 specified in AN75779 where I temporarily suspend video streaming and configure with still resolution and capture image.
My common issue for these two scenarios is DMA_RESET repeatedly according to the UART logs.
Please help me in this.
Thank you,
Abdul.
Hi Abdul,
Could you please share the UART logs with us?
Please find the latest AN75779 firmware in the FX3 product page. The default firmware supports still image capture method 2. Please compare this with your firmware.
AliAsgar
Hi Abdul,
AliAsgar
