For the last few days, I'm trying failsafe firmware update as explained here , I'm using the same code and followed the same steps as mentioned, first I merged 2nd stage boot loader and UsbBulkSrcSink and then flashed to my Denebola Kit, and It successfully shows itself as a device in the control center, but later when I try to update new firmware(USBBulkloopAutoEnum from examples) with given Firmware Updater, I flashed new firmware with given Firmware updater, but It didn't execute in Denebola Kit. Even in the control center, I didn't get anything to see.
USB Superspeed Peripherals
Are you able to get the USBBulkLoopAutoEnum firmware working? If yes, please elaborate the fix that you did so that we can check if it is proper or not.
I tried to test the default projects as it is and was able to get the USBBulkLoopAutoEnum enumerated properly without making any changes to the code. The only thing is that you will not be able to make any further firmware updates. This is because the default USBBulkLoopAutoEnum does not handle the vendor commands issued by Fx3FirmwareUpdate utility for further firmware updates.
Jayakrishna
Can you please share the merged image file for us to check? Also, please let me know if you are using debug or release builds.
Jayakrishna
Can you share the USBBulkloopAutoEnum firmware used for testing? Also, does the Fx3FirmwareUpdate utility show status as Success or Fail when you program USBBulkloopAutoEnum ?
Jayakrishna
Yeah I'm getting success after updating. check screenshot once
Can you please try the following tests and let me know the result of each of them:
1. After updating the firmware (with USBBulkLoopAutoEnum ) using Fx3FirmwareUpdate utility, just press on reset button and see if you are able to get the device enumerated.
2. Try programming USBBulkSoruceSink image itself using Fx3FirmwareUpdate utility and see if you are able to get the device enumerated properly.
3. Program the USBBulkLoopAutoEnum firmware into RAM directly using control center application and check if you are able to see the device enumerated or not.
Jayakrishna
I tried removed Firmware update check for Firmware2 then It is totally working fine.
Jayakrishna
Thanks for support Jaya Krishna, fail-safe firmware is working fine as you said
