kir_4703346
USB3CV test fails with following error, When uncompressed format Y16 or Y8 used.
INFO Uncompressed Video Format Descriptor guidFormat is not a recognized YUV variant ({20203859-0000-0010-8000-00AA00389B71}).
FAIL (UVC: 6.10.2) Uncompressed Video Format Descriptor guidFormat is not a recognized YUV variant.
INFO CV does not recognize this GUID as a variant of YUV
GUID format used for Y16
20363159-0000-0010-8000-00AA00389B71
GUID format used for Y8
/* Class specific Uncompressed VS format descriptor */
0x1B, /* Descriptor size */
ES_UVC_CS_INTRFC_DESCR, /* Class-specific VS interface Type */
0x04, /* Subtype : VS_FORMAT_UNCOMPRESSED */
0x01, /* Format desciptor index */
0x04, /* Number of Frame Descriptors that follow this descriptor: 1 */
/* GUID, globally unique identifier used to identify streaming-encoding format: Y8 */
0x59,0x38,0x20,0x20,//Y8
0x00,0x00,0x10,0x00,
0x80,0x00,0x00,0xAA,
0x00,0x38,0x9B,0x71,
0x08, /* Number of bits per pixel */
0x02, /* Optimum Frame Index for this stream: 1 (1596x1300) */
0x00, /* X dimension of the picture aspect ratio; Non-interlaced */
0x00, /* Y dimension of the pictuer aspect ratio: Non-interlaced */
0x00, /* Interlace Flags: Progressive scanning, no interlace */
0x00, /* duplication of the video stream restriction: 0 - no restriction */
Class specific Uncompressed VS frame descriptor 1
Class specific Uncompressed VS frame descriptor 2
Class specific Uncompressed VS frame descriptor 3
Class specific Uncompressed VS frame descriptor 4
 Still image descriptor
0x03, /* Format desciptor index */
/* GUID, globally unique identifier used to identify streaming-encoding format: Y16 */
0x59,0x31,0x36,0x20, // Y16
0x10, /* Number of bits per pixel */
Hemanth
First like given First question asked 750 replies posted
Y16 and Y8 are not standard YUV formats and hence CV test fails for these formats. Below link provides standard YUV variants.
https://docs.microsoft.com/cs-cz/windows/win32/medfound/video-subtype-guids#luminance-and-depth-form...
You can also see the same problem discussed in msdn forum as well:
https://social.msdn.microsoft.com/Forums/WINDOWS/en-US/c0531030-67a5-4b0d-a8e0-5c06ca0994af/uvc-y16-...
Windows in box UVC driver does not support Y16 format where as Linux does.
Hemanth
Hemanth
Can you please try YUY2 GUID just for compliance test. It is given below:
0x59,0x55,0x59,0x32, /* GUID used to identify streaming-encoding format: YUY2 */
Hemanth
kir_4703346
Yes, with YUY2 format compliance test passed.. But my question is.. i want to use two format, one  Y8 and another format Y16. However if i can replace YUY2 for Y16 since both are 16bit formats. How can i use Y8 here
Hemanth
The reason why I asked to try first with YUY2 is just to make sure rest of the descriptors are fine and that only problem with formats.
Is it possible for you to attach firmware project?
Hemanth
kir_4703346
I have attached the SS configuration with YUY2 and Y8 formats for your reference
Hemanth
Hemanth
