Do we have to re-run the USB-IF Certification for FX3 if we use a different Vendor ID?
USB Superspeed Peripherals
As you might already know FX3 is compliant to USB 3.1 Specification Revision 1.0 (TID # 340800007) as mentioned in datasheet.
However, since you might be making your own custom PCB for the product, you will have to run the compliance tests.
Do these tests have to be run in an official certification venue like UL or can these be run at home and we can self claim USB-IF compliant?
USB-IF compliant tests should be run at GRL (Granite River Labs).
UL is not a venue and is different from USB-IF certification.
Below link can be referred:
