- Email to a Friend
Hello Sir/Mam
We are planning to use the part CYUSB3014-BZXI in our design but the FPGA we are using only supports 1.5V I/O voltage level. SO could you suggest how can we interface it with our FPGA . And Is there any other part that supports 1.5V I/O level.
USB Superspeed Peripherals
- Email to a Friend
FX3 works at a minimum of 1.7V so you can use some bus level shifter.
Biren
- Email to a Friend
I understand that you need to add USB 3.0 functionality to your application but the FPGA supports only 1.5V IO voltage. Is my understanding correct?
If yes, as you are aware FX3 supports min voltage of 1.7 V on VIO1/VIO2 (GPIF interface). Please confirm that you want to have an application as mentioned in AN65974 i.e. interfacing FPGA through GPIF II interface
Rashi
- Email to a Friend
Hello
I understand that you need to add USB 3.0 functionality to your application but the FPGA supports only 1.5V IO voltage. Is my understanding correct?--CORRECT
If yes, as you are aware FX3 supports min voltage of 1.7 V on VIO1/VIO2 (GPIF interface). Please confirm that you want to have an application as mentioned in AN65974 i.e. interfacing FPGA through GPIF II interface--Yes,We are interfacing through GPIF II interface
- Email to a Friend
Biren
- Email to a Friend
Hello
Can you suggest some Part for BUS level shifter which will serve the purpose.
- Email to a Friend
Sorry we don't have any reference design for this but I think you can search the "BUS level shifter" keyword in google and get some design references, you may need to modify the reference design based on your clock and voltage.
Biren
