TBencher
250 replies posted First like given 50 sign-ins
Hi community,
just wondered about how to connect CYEZUSB3KIT - 003 board with armx64 driven Windows 11 system.
Did not find any suitable drivers within the installation package.
Thank you.
Best,
TBencher
AliAsgar
250 solutions authored 750 replies posted 50 likes received
Hi TBencher,
If thats the case, unfortunately, we do not have cyusb3.sys driver for Windows 11 in ARMx64.
AliAsgar
AliAsgar
Please test the driver mentioned in the attached thread link. https://community.infineon.com/t5/USB-superspeed-peripherals/CYAPI-on-Universal-Windows-Platform/m-p...
Please notify us if this driver is not compatible with Windows 11.
AliAsgar
TBencher
Hi Ali,
after disabling signature check enforcement, I was able to install it.
However, this driver does not work as well, unfortunately.
Best,
TBencher
AliAsgar
Hi TBencher,
Please try to manually bind the device to the driver and check.
AliAsgar
TBencher
Hi Ali,
I tried it manually. System does not recognise this driver to be compatible with Windows 11 ARM64.
Best,
TBencher
TBencher
Hi Ali,
is WestBridge the vendor who makes the device drivers for you?
I cannot find this company. Just wanted to check whether they have an update available.
Best,
TBencher
AliAsgar
Hi TBencher,
The cyusb3.sys driver has been developed in-house. Please manually bind the driver to cyusb3.sys driver provided to you in the zip folder. Please google on steps to manually bind driver to a device.
AliAsgar
TBencher
Hi Ali,
thanks for the information. We did already try to bind it manually.
We will move to another machine with legacy Windows OS now.
TBencher
AliAsgar
Hi TBencher,
AliAsgar
TBencher
Ok, thank you.
TBencher
