I am using a USB 3.0 hub "CYUSB3314" to get 4 connectors from a single connection comes from a CPU. I know how should I connect the upstream connection to a connector but I am confused how to connect that to a CPU. is it going to be like a connector (TX_M to TX-, TX_P to TX+, RX_M to RX-, RX_P to RX+) with having swapping option between each polarity or should I connect TX to RX in each side?
Thank you in advance.
If you're connecting the upstream port to a CPU directly, the lines would have to swapped as in the connection 2 diagram. This is because, in case of a connector, the cable takes care of swapping the lines so you wouldnt need to swap them on your board.
You could also refer to the KBA- https://community.cypress.com/t5/Knowledge-Base-Articles/HX3-FAQs-KBA224063/ta-p/260248
Sananya
Sananya
Thank you for the fast and clear answer.
Amin.
