U3V CyFxU3VUpdateSerialNum updated wrong address data
yiwa_4244806
First like given
Hi there,
When I was reviewing source code for FX3 U3V device, I found a question as below:
the function source code is:
uint32_t *uniqueIDreg = (uint32_t *)0xE0055010;
void CyFxU3VUpdateSerialNum(void)
uint8_t j=0;
uniqueIDL = *(uniqueIDreg);
uniqueIDH = *(uniqueIDreg+32);
for(j=0; j<4; j++)
CyU3VABRM[260+j] = ((uniqueIDL>>(j*8))&0x000000FF);
CyU3VABRM[264+j] = ((uniqueIDH>>(j*8))&0x000000FF);
It is to update the unique ID serial number from register whose address is 0xE0055010.
But!
uint8_t CyU3VABRM[528] =
0x00, 0x00, 0x01, 0x00, // GenCP Version: Minor version (16bits) = 0x0000 , Major version (16bits) = 0x0001
U3V_MANUFACTURER_NAME, // Manufacturer Name String in ASCII, 64 bytes
U3V_MODEL_NAME, // Model Name String in ASCII, 64 bytes
U3V_FAMILY_NAME, // Family Name string in ASCII, 64 bytes
U3V_DEVICE_VERSION, // Device Version String in ASCII, 64 bytes
NULL_64, // Manufacturer info string, 64 bytes, NULL            <-----------------Wrong! CyU3VABRM[260+0] begins here!!!
NULL_64, // Serial Number string, 64 bytes, to be filled during runtime by CyFxU3VUpdateSerialNum()
How this happens?
BTW, could anyone tell me a fake 8-byte unique ID serial number to test? The host seems stall after the 8-byte data received.
Or could help provide the dump data of these sequence?
Tks so much!!!
You could modify the code of function CyFxU3VUpdateSerialNum on your side.
yiwa_4244806
First like given
YangyangC_06
Hi, Yang,
Can we return the an exist serial number string directly?
How did you get the U3V project?
I got from
FX3 application note for USB3 Vision | Cypress Developer Community  https://community.cypress.com/message/127077#127077
But this example seems with bug:(
Tks for your reply!
PS.
uint8_t CyU3VManifest[] =
0x01, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00,   // No. of Manifest entries = 1
0x00, 0x00, 0x00, 0x01,   // GenICam file version 1.0.0
0x00, 0x00, 0x01, 0x01,   // Schema/Filetype Uncompressed xml ver. 1.1.0
U3V_XML_ADDR,     // Address for XML file
0xFF, 0xFF, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00,   // Size of xml file (8 bytes width)
NULL_20,      // SHA-1 for xml - not available
NULL_20       // Reserved
This xml file size also seems incorret:(
Could you help please tell us how to get the one correct demo or example without bugs?
Tks so much!
Hi
The source code for U3V was built for demo purpose, not for release. Cypress doesn't have update from last version.
Thus you may refer it to build your customized application.
