I have an FX3S design which I would like to transition from I2C boot to eMMC boot (connected to the Sib port). I see information in the manual on how to attempt that directly with the PMODE pins. Unfortunately, my design uses a version of the two-stage bootloader (I2C) to allow device updates and the boot_fw library doesn't support Sib boot, is that true?
Is it possible to implement a two-stage bootloader with only the eMMC? I would like to eliminate my I2C eeprom components.
Thanks!
We do not support SIB in Boot library. So, it is not possible to implement two-stage bootloader with only eMMC.
Jayakrishna
Jayakrishna
