I have generated my own config. file from the Image sensor configuration. I got the below errors when connecting to PC(Windows 10).
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
For your reference, pls find the attached file and device descriptor(.zip file)
Please refer to this Solved: CX3 configuration utility source code - Infineon Developer Community thread with a similar issue.
Also, confirm if the steps in this Steps to Setup up MIPI CSI Camera Solution with CX... - Infineon Developer Community KBA are followed
Please let us know if this solves the issue
Rashi
Rashi
