ZhYa_2401356
Our device dropped frames after extending the long line. So we want to measure The rate of USB3.0 transmission of the 1080p@30fps's YUV image before extending the long line and after extending the long line. Can you offer a real measurement data or measuring method?
KandlaguntaR_36
25 solutions authored 10 solutions authored 5 solutions authored
What do you mean by extending the long line here.
Which chip you are using here? FX3 or CX3?
Can you share the the FV (High, Low), LV(High, Low) and PCLK values in working case and extending the long line case>
KandlaguntaR_36
