We are about to sign the latest driver cyusb3 from SDK 1.3.4 with Windows Hardware Lab Kit (HLK). The tests are run for Windows 10, x64 build 19041, which is latest version.
Following tests are failing:
- HyperVisor Code Integrity Readiness Test
WDTF_TEST : Non-zero Code Integrity statistic found:: Execute Pool Type Count : 514
- USB Device Connection S3 + S4 + Connected Standby
IOCTL_USB_GET_PORT_CONNECTOR_PROPERTIES returned invalid port number
What can be done to pass the tests? We successfully signed drivers for older driver versions and/or Windows builds.
Thanks in advance for any help
Hop you are using the 1.2.3.20 driver package from FX3 SDK and changing only the inf file by adding the custom INF entries.
Can you please provide the modified INf?
Please try using a different port as mentioned in the below article for USB Device Connection S3 + S4 + Connected Standby test:
USB tests in the Windows 10 Hardware Lab Kit (HLK) - Microsoft Tech Community
For HyperVisor Code Integrity Readiness Test Please refer to the below thread:
Having trouble with Windows 10 HLK "HyperVisor Code Integrity Readiness Test"
Yatheesh
Please confirm the below:
1. Is the required version of HLK installed on the server and the client systems( Windows 10 version 2004 😞 Windows Hardware Lab Kit | Microsoft Docs
2. Is the playlist loaded as mentioned in this step: Step 6 Select and run tests | Microsoft Docs
If no, please download the playlists from this link and load it (HLK Version 2004 CompatPlaylist x86 x64 ARM64.xml) to filter out unwanted tests: Windows Hardware Compatibility Program | Microsoft Docs
Yatheesh
Hello Yetheesh,
thanks for your answer. I can confirm both. On both systems version 2004 (build 19041) is installed and we loaded correct playlist 'HLK Version 2004 CompatPlaylist x86 x64 ARM64.xml'.
Thank you
Benny
Hello Benny,
Please let me know which device and firmware you are using for the testing purposes?
Also, please share the logs for the failed tests.
Yatheesh
Please use the USBBulkSrcSink or USBBulkLoopAuto unmodified firmware from the FX3 SDK for HLK log collections.
Yatheesh
Please send me the screenshots of HLK studio:
1. Test fail details under Results tab
2. PC and driver selection under Selection Tab
3. Tests Tab
Please note that we have performed the tests with no failure.
Yatheesh
Yatheesh
Hello Yatheesh,
thanks for your answer. Especially the first link helped a lot. Now we can pass both Tests.
Thanks for your quick help and best regards
Benny
