I am using ECON Denebola CX3 Development Kit. I am using a peripheral for which I need to control MIPI_CAM_PWDN and MIPI_CAM_RST. After calling CyU3PMipicsiInitializeI2c(), CyU3PMipicsiInitializeGPIO (), CyU3PMipicsiInitializePIB (), I am calling the following function to set MIPI_CAM_PWDN and MIPI_CAM_RST.
CyU3PMipicsiSetSensorControl(CY_U3P_CSI_IO_XRES, CyTrue); // Set MIPI_CAM_RST to High
CyU3PMipicsiSetSensorControl(CY_U3P_CSI_IO_XSHUTDOWN, CyTrue); // Set MIPI_CAM_PWDN to High
Is this the correct way? On the HUD E-Con Breakout Board, I checked TP_SHUTDN using a logic analyzer, but I don't see this line going High.
Is the above CyU3PMipicsiSetSensorControl() call the right way to set the MIPI_CAM_PWDN and MIPI_CAM_RST lines?
Thanks for your help.
Subramanyan
USB Superspeed Peripherals
Please follow the below sequence
CyU3PMipicsiInit >> Initializes the MIPI Block of CX3
Rashi
Rashi
