Dear Sirs,
I am working on the USBAudioClass Example - but get no sound from the kit.
In debugging this I want to verify the PCM file I actually stored in the SPI, using USB BootProgrammer Device.
But now, no matter what I try, I get SPI busy. I have of course waited (more than an hour), but it just do not seem to get back from being busy.
I have flashed the device with the factory default image (USBBulkSourceSinkLED). This is still working.
But as soon as I reflalsh the USB BootProgrammer, and access the SPI, I get Busy.
I am following the the guide in the readme.txt under the USB BootProgrammer.
I have also read and tried out suggestions from many of the similar posts.
Examples of the Control Center screenshots exercises to be found in attached .zip.
I just want to flash and make a verify by reading (Read File).
I get a success in resetting the SPI; but when ever I try to read (Transfer Data or Transfer File), I get error code 997.
My system is WIndows 10. Both Windows, and the Dev kit is newest and updated.
It would be really nice to get some input, to proceed.
Best Regards
USB Superspeed Peripherals
Hello Michael,
This hardware doesn't have SPI flesh so it will always fail.
Biren
Can you please send this attached.zip file which you maintain on description and please send the full UART log for timeout error?
This old question explains the same workflow you can follow this explanation.
Biren
Hello Michael,
Can you please share your dev kit part number?
Biren
Hi Biren,
On the box it says
CYUSB3KIT-003 Rev B
2112CN00346
on the printet label of the PCB it says:
121-60162-01
Rev 05
2112CN00346
Best Regads,
Michael
Hello Michael,
Biren
Hello Biren,
That explains it:-)
Do you know of any example code for this board, where I can stream audio?
It does not have to be official.
And do you know why debug info is not printed in a serial terminal for the Boot Programmer sw?
Michael
Hello Michael,
Sorry, we don't have any official audio stream examples which work CYUSB3KIT-003 out of the box, you can try by modifying the USBAudioClass example and reading the sound file from the I2C memory in lace of SPI, and you need to save the file in I2C memory also.
And about debug print in this Boot Programmer FW it was sending data to another UART pin which not connected to USB to serial because when we are using SPI pin is use the same USB to serial UART pin as SPI.
To read UART debug you can use GPIO[48], GPIO[49], and connect to external USB to serail.
Biren
Thanks Biren,
Michael
