Is it possible to program SPI ROM for FX3 firmware without using Control Center?
If don't have any solution from cypress, how about any third party product?
The SPI slave that is used should match the following write commands for successful programming from the USB Control Center.
In case the commands are different, the USB Control Center can be modified to suit the slave device that is used. The source of the control center can be found from the below path after the installation of FX3 SDK.
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\application\c_sharp\controlcenter
Srinath S
Srinath S
