subk1234
5 questions asked First like given 5 sign-ins
I am working on a ECON Denebola CX3 development Kit. I need to interface with an image sensors which uses SCCB for configuration. Will the I2C calls, CyU3PI2cTransmitBytes() and CyU3PI2cReceiveBytes(). I am using these functions, but I am facing the following issues.
1. If I add the I2C address as documented, it does not work.
2. I wrote an I2C scan to communicate with any address. The peripheral responded to a few addresses, but I get an error CAMERA_CY_U3P_ERROR_LOST_ARBITRATION.
Any help or documentation on this is greatly appreciated.
Thanks and Regards,
Subramanyan
JayakrishnaT_76
Moderator First question asked 1000 replies posted 750 replies posted
Hello Subramanyan,
Can you please elaborate the term SCCB? Also, can you please share the complete project for us to check?
Jayakrishna
subk1234
Hi Jayakrishna,
SCCB is Serial Camera Control Bus used in Image Sensors. The CX3 is interacting with Image Sensors over SDA and SCL.
Thanks and Regards,
Subramanyan
JayakrishnaT_76
Hello Subramanyan,
Can you please share the project along with the UART debug logs for us to check?
Jayakrishna
