May 28, 2019
10:01 AM
May 28, 2019
10:01 AM
Use cyusb3014 with FPGA.
Pin GPIO[27] connected with FPGA.
GPIF is configured with a 32-bit data bus. Cyusb booting from SPI.
i2c connected to display for log.
i want send packet on UART from FPGA to Cyusb on pin gpio[27].
Can be used UART hardware controller or only program controller?
- fx3 gpio
11:45 PM
May 28, 2019
11:45 PM
For the mentioned configuration, the UART hardware block will be available on pin GPIO[53:56]. GPIO27 cannot use UART hardware. Instead it should be implemented on the firmware.
Srinath S
11:45 PM
May 28, 2019
11:45 PM
Srinath S
