USB superspeed peripherals Forum Discussions
ankitvats846
10 replies posted 10 sign-ins 5 questions asked
I have Firmware for Fx3 running with GPIF 32 bit mode.
Also need to Read/Write on the SPI flash . For that need to Reconfigure the  GPIF  mode to 16 bit.
For Reconfiguring  I   do
                                                  1)  Disable the GPIF(CyU3PGpifDisable ( CyFalse ))
                                                  2)  Reconfigure the IOmatrix
        a) io_cfg.isDQ32Bit = CyFalse
        b) io_cfg.useSpi = CyTrue
                                                     By doing this Enable the SPI.
                                                   3)  Initialize the SPI interface for flash.
Is this Possible to configure at run time ? if Yes what is the right way??
Rashi_Vatsa
Moderator 500 solutions authored 1000 replies posted 750 replies posted
Reconfiguration of the IO Matrix can be done. But please make sure that all the initialized blocks should be de-initialized and re-initialized again.
Please refer to similar threads  Solved: Any dependencies by switching/reloading GPIFII? - Infineon Developer Community
-   Solved: CYUSB3014 FX3 GPIF Reconfiguration - Infineon Developer Community
Rashi
Rashi_Vatsa
Rashi
ankitvats846
Hi ,
I able to Reconfiguration of the IO Matrix on run time.
How much  ideal time it will take to Reconfiguration of the IO Matrix ??
My Firmware is taking 5-6 sec to Reconfiguration.
Rashi_Vatsa
Can you please share the code snippet where the reconfiguration is done?
5-6 seconds seems to be quite long
Rashi
