Hello.
The last revision of FX3S is a revision D.
What did year the release of revision D start?
If the chip has YYWW of 2017, you can consider it as silicon revision D (latest Rev.).
I need to check internally to answer your question
Sridhar
Hello.
The supplier offers me a chip of 2017 release. Can I be sure that this year has already been the production of the last revision D?
The labeling of the chip does not indicate revision, and this is distressing. The supplier cannot tell me about the audit due to the lack of data about it. Only year of production.
Thank you so much for the quick response.
