- Email to a Friend
Hi, I have a C++ program that sends data from my Linux host PC to the FX3, and then has the FX3 return that data back to the host. I would like to read some registers and log them in a file on my host PC during all of these data transfers. I've found the CyU3PReadDeviceRegisters() API function, but I don't know if it needs to be in the C++ program I wrote, or the firmware I have downloaded onto the FX3 using the USB bootloader. I am using the cyfxbulklpautoenum image file that comes with the Linux cyfx3sdk.
To summarize, can I get an example program or code snippet describing where to use the CyU3PReadDeviceRegisters() function (either in firmware or C++ program) and how to log that data for each transfer onto my Linux host computer?
Thank you.
USB Superspeed Peripherals
- Email to a Friend
The API that you are referring to (CyU3PReadDeviceRegisters) is a part of FX3 firmware library. So, it should be used in FX3 firmware only. You can try to read the registers in firmware and return it to the host as a response to a vendor command.
Jayakrishna
- Email to a Friend
Jayakrishna
