If I configure the MIPI block as RAW10 (as shown in the code below), but the GPIF bus is set to 8 bits, what will happen?
My guess is only the first 8 bits of each pixel get sent.
i.e. Camera sends this info for each pixel: Pix[9:0]; MIPI block sends to GPIF only Pix[7:0]
Is this correct?
MIPI configuration:
CyU3PMipicsiCfg_t cfgUvc1080p30NoMclk = {
CY_U3P_CSI_DF_RAW10, /* dataFormat */
2, /* numDataLanes */
1, /* pllPrd */
62, /* pllFbd */
CY_U3P_CSI_PLL_FRS_500_1000M, /* pllFrs */
CY_U3P_CSI_PLL_CLK_DIV_8, /* csiRxClkDiv */
CY_U3P_CSI_PLL_CLK_DIV_8, /* parClkDiv */
0x00, /* mclkCtl */
CY_U3P_CSI_PLL_CLK_DIV_8, /* mClkRefDiv */
1920, /* hResolution */
0x01 /* fifoDelay */
GPIF configuration:
status = CyU3PMipicsiGpifLoad(CY_U3P_MIPICSI_BUS_8, ES_UVC_DATA_BUF_SIZE);
Yes, your guess is correct.
