- Email to a Friend
Hi, I have interfaced the camera sensor to FX3 board. The output data is in the YUV2 format (as default in AN75779). I want to display the data in RAW format. Does FX3 support sending RAW data through USB?
How can I do that and where I need to do changes accordingly.
Please suggest~
/Ash
USB Superspeed Peripherals
- Email to a Friend
As mentioned earlier, RAW formats are not supported by UVC driver. If the GUID is set to RAW format, UVC driver might drop the data which is sent by FX3 and no video can be seen in Standard Video applications. Please refer to this KBA
As the sensor is streaming RAW16, you can stream the data as YUY2 format (16 bits/pixel). Please note this will show greenish/pinkish video stream on UVC application as the UVC driver will accept the data assuming it is YUV formatted and try to decode it.
So, it's necessary to create a custom host application to decode this RAW16 assumed to be YUV video format properly.
Rashi
- Email to a Friend
Please refer to section 9.4 of the app note for the instances were the changes needs to be done
As you want the output video format as YUV2, the video format in the descriptor can be kept same and accordingly the video resolution should be calculated (to populate in th descriptors)
For example:
Original video frame size: 1280*720 * 1(mono) = 921600 bytes
As video will be sent as YUV2 (16 bytes/pixel), video frame size = 640 * 720 * 2 (YUV2) = 921600 bytes
Rashi
- Email to a Friend
@Rashi_Vatsa Hi, Thanks.
I want to display mono raw data (qvga) stream, not yuv2 format. The application note defines descriptior which defines the output format as yuv2.
How can I set output data format as raw (mono)?
Please suggest~
/Ash
- Email to a Friend
To change the output format in AN75779, please make necessary changes in GUID used to identify streaming-encoding format field and Number of bits per pixel used field of the Class specific Uncompressed VS format descriptor
Please note applications like AMCap, eCamViewer do not support RAW format streaming. Please use appropriate UVC host app to view the RAW video stream
Rashi
- Email to a Friend
@Rashi_Vatsa Hi.
This defines in application note as "GUID used to identigy streaming-encoding format:YUV2" for setting output format as YUV2.
/* GUID used to identify streaming-encoding format: YUY2 */
0x59,0x55,0x59,0x32,
0x00,0x00,0x10,0x00,
0x80,0x00,0x00,0xAA,
0x00,0x38,0x9B,0x71,
Where I can find the GUID for RAW format, any suggestions?
Also, please let me know any available host application which can stream raw data.
/Ash
- Email to a Friend
Please refer to this thread Solved: USB compliance Test fails with error in GUIDformat... - Page 2 - Infineon Developer Communi...
Rashi
- Email to a Friend
@Rashi_Vatsa Hi,
I tried to go through it but didn't get much from it. During, I found this and tried to set it up with most of the required formats (Y16), but didn't work. https://www.fourcc.org/yuv.php
Is there any working GUID for Y16, or mono format, please suggest~
- Email to a Friend
Please let me know if this works for Y8
'Y', '8', ' ', ' ',
0x00, 0x00, 0x10, 0x00,
0x80, 0x00, 0x00, 0xAA,
0x00, 0x38, 0x9B, 0x71, // End of GUID
0x08, /* Number of bits per pixel: 8 */
Rashi
- Email to a Friend
I'll give it a try and update.
well, since my data is 2byte coming on 8bit parallel port from sensor, Should I not use Y16 format? like this if it allows....
'Y', '16', ' ', ' ',
0x10, /* Number of bits per pixel: 8 */
- Email to a Friend
@Rashi_Vatsa Hi,
I tried with this...
'Y', '8', ' ', ' ',
this gives me buidl error as: error: empty character constant
please suggest~
- Email to a Friend
I have tried building AN75779 with the Y8 GUID and 8bits/pixel settings in the descriptor file and it builds successfully.
Please find the modified descriptor file. Please note that the only modification done in the file is GUID (Y8) and bits/ pixel
For using Y16, following are the settings
0x10, /* Number of bits per pixel: 16*/
Rashi
- Email to a Friend
May I please know which host application are you tested with to stream the raw data?
best regards,
- Email to a Friend
We haven't tested streaming Y8/Y16 format as UVC applications like e CamViewer, AmCap doesn't support these formats.
You can try streaming using the Windows in- box camera
Rashi
- Email to a Friend
@Rashi_Vatsa Hi,
Do you mean using the default windows10 camera app or any other? I am not sure but does it support raw streaming?
Regards.
- Email to a Friend
@Rashi_Vatsa Hi,
I tried it with windows default camera app, but nothing came up.
Please suggest~
Regards.
- Email to a Friend
RAW formats are not supported by UVC specification.
You can stream these formats as YUY2 using UVC host applications like AmCap, MPC-HC
Although, we have seen some customers using Potplayer for streaming Y8 format on Windows but we haven't tested it at our end. You can try testing at your end
Rashi
- Email to a Friend
@Rashi_Vatsa Hello.
Yes, I tried with Potplayer with Y16 format. It gives me codec error...
though I defined 'Y16' as format, player takes it as 'Y6', don't know why?
Regards.
- Email to a Friend
Apologies for mistake.
Can you please try this GUID and let me know if it works
'Y', '1', '6 ', ' ',
Rashi
- Email to a Friend
@Rashi_Vatsa Hello.
Thanks for sharing this, I tried it again and I got.
'Y','1','6',' ',
Regards.
- Email to a Friend
Please check if Y8 works fine. As mentioned earlier, we have seen some customers using Potplayer for streaming Y8 format on Windows
Rashi
- Email to a Friend
- Email to a Friend
Rashi
