Hi,all
I would like to use GPIF DESIGNER to read and write NANDFLASH. I found that when I use DR_DATA and IN_DATA to
drive the data bus, the length of time and interval can not be changed, and I do not need such a long time.As a result I can not exactly optimize the timing of the design as I need.Can I change length of time when drive data bus?
Thanks!
Feng
You can set the interface clock to max frequency/100MHz. You cannot change anything further to change the signal timing.
Thank you, Nishant.
