Hello all,
I need to send USB requests to my FX3 device and I would like to use python.
I have a video streaming application based in the cypress firmware example AN75779. I can send USB requests using cyusb3.sys driver and CyUSB.dll in a C# application.
Is there any API that I can use to interface with Cyusb3.sys driver with python instead of the C#/C++ dll/API? I've seen some posts talking about this issue but they are a little bit old and maybe outdated.
Also, I see that some developers are using a different driver (libusb) and interfacing with pyusb. May this solution work with AN75779 firmware?
Thank you very much in advance for the support!
- cyusb3.sys
- fx3
- python
We do not provide python wrappers with cyusb3.sys driver. You can refer to the thread below: https://community.infineon.com/t5/USB-superspeed-peripherals/Is-there-Python-wrapper-with-the-CYUSB3....
AliAsgar
AliAsgar
Hi AliAsgar,
thank you for the reply. I understand, I would try with CyAPI.h in C++.
Thank you!
Best Regards
