SaLa_1789541
5 likes given First like given
Hello Everyone,
I am programming my FX3 using usb control center utility, and when i program using SPI flash mode it ask for img file and start programming of spi flash, but it stucks there only. how to solve this problem? i have connected jumper on PMODE J4. and it works fine when programming RAM and i2c eeprom but troubles me when programming spi flash. Please help
thanks
Hi Sagar,
CYUSB3KIT-003 doesn't have onboard SPI FLASH.
YangyangC_06
Hi Sagar,
Which board are you trying to program?
EZ-USB FX3 CYUSB3Kit-003
Hi Sagar,
how much memory is there in i2c eeprom in fx3?
The EEPROM is 2M bit. You could download the datasheet here
https://www.st.com/resource/en/datasheet/m24m02-dr.pdf
Thanks for your help
have a nice day
Have a nice day, too.
